S
sean.snider
Hello - I've just purchased a 1998 coupe - 6 speed. Very happy with it, got a decent price and it only had 19,000 miles on it. Naturally, I declined any kind of a warranty...
So - I have put about 1,000 trouble free miles on it - then, yesterday, I ran into some problems... Here's the sequence of events:
Fully warmed up engine (15-20 minutes run time), driving about 65-70 mph on the interstate - got the Check Engine Light, the Traction Control Light, and the DIC indicated reduced engine power. It knocked me down to an idle - I worked it over to the side of the road, turned it off, waited a minute or two (caught my breath and calmed down a bit) and restarted the car. On restart the car seemed to run fine, but the Check Engine Light is locked in. Even after 5 or 6 cycles/starts and shutdowns, of the engine.
I checked all the threads here hoping to find some answers and got some really good clues. But, after pulling the Codes (thanks c4c5 specialist!) I'm not sure....
Here are the codes that I pulled:
10-PCM P1518
28-TCS C1278
60-IPC B0521
AO-LDCM B2252, B2282, B2284, U1064, U1016, U1096, U1255
A1-RCDM B2283, B2285, U1064, U1016, U1096, U1255
A6-SCM B0851, B2605, U1160
Also - here is the serial number:1G1YY22G5W5116803 (how can I tell if it has had the Steering Lock recall work done?)
Any suggestions would be very much appreciated...
10-PCM P1518
28-TCS C1278
60-IPC B0521
