Check Engine Light
  • Thread starter Thread starter jorge33265
J
jorge33265
I need some help trouble shooting these codes. Any help would be greatly appreciated. I have a 1997 Corvette Auto. Coupe.
Im getting the following codes
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
B0361 Left Actuator Feedback Short to GND
B0441 Left Actuator Out of Range
Mainly any help i can get with the P0141 would help me alot. I think thats the one that is actually setting off the check engine light. Does this mean i need to change my O2 sensors? I cleared the computer codes and they came right back after 30 minutes or so.
HI there,
Yes, your oxygen sensor, located on the drivers side underneath the car in the H pipe is causing your code.
Normally, this would require replacement of the sensor. Be careful, as the wiring will cross over the exhaust and go down the passenger side of the tunnel.
I have seen alot of tech confuse the position based on the wiring.
It will most likely be replaced.
Allthebest, c4c5:hb
