Anytime I try to check the oil hot it is smeared all over the dipstick and I can't tell the level only that the bottom hole has oil in it. My 2001 uses a quart about every 2500 miles and has 30,000 on it,should I get it worked on under warrenty as I only have 6000 miles left. I check the oil level cold and can get a good reading but the book says check it hot. Lyle
