tls630
Does anyone have a secret? I have tried brake clean, wheel cleaner, some differant aluminum cleaners, and simple green and stiff brushes. It still doesn't look very good. What do you suggest?? tls
Yeah,Me too,But I got mine at the Kawasaki Dealer!off the car glass beads work great, on the car I would not know. Back in my Motorcycling days I used a product called S-100 available at your local Harley dealer spray on rinse off worked great on the bike.
Oxidation of the aluminum causes intake runners and other aluminum parts to get dull and discolored. There are aluminum brighteners you can buy that may help, but the results could be spotty and make things look worse. By the way, don't try to clean or scrub your valve covers - they are powder coated magnesium.Does anyone have a secret? I have tried brake clean, wheel cleaner, some differant aluminum cleaners, and simple green and stiff brushes. It still doesn't look very good. What do you suggest?? tls
I painted mine with paint purchased from Mid America -- with good results.Thats strange because there are several accounts here on the forums of people using valve cover paint and had good results. I am wondering if anyone has painted the magnesium valve covers??
I worked on the plenum yesterday using elbow grease and wd-40.. it worked better than anything I have tried yet!! I also put a liberal amount of it on the valve covers.. They look nice, except I have a couple small stains.. Any more suggestions?
Paint will not work.. they are powder coated magnesium.. I had some junk ones that I bead blasted and bought the valve cover paint from Ecklers. The paint was nothing more than an aluminum paint and they looked worse when I got done than they did before..
I didn't spray the paint on - I sprayed it into a small container and then used a small brush and q-tips to apply the paint to the valve covers. In my case only the tops of the valve covers were discolored so I didn't have to remove them from the engine to paint them. If you do want to take off the valve covers, the one on the driver's side is no problem but the one on the passenger side is blocked by the A/C compressor. Also you may not want to remove the valve cover in any case because you might end up with an oil leak when you put the valve cover back on. If you don't have a leak now, why ask for trouble??
All my attempts to "clean" the valve covers only made things worse. I even tried toothpaste! Either re-paint them or buy new one$.
What's with the WD40? Does it act as a cleaner?
