soggytaco
What is the best way to clean your engine compartment? I am affair spraying water on it will ruin the electronics.
junk!! ps if it's got a Opti Spark cover it with a plastic bag or something!!That's why I run 200 deg. water through my Pressure washer!!Aurora40 said:Sorry, an All Purpose Cleaner. They are usually strong enough to remove grease and grime, but less strong with less potential for damage than a degreaser or other strong cleaners. I use Meguiar's All Purpose Cleaner Plus, though they no longer make it. Simple Green would be considered an APC, though one I've found to be somewhat corrosive (I'm not a Simple Green fan).
junk!!Thanks!Aurora40 said:Sorry, an All Purpose Cleaner. They are usually strong enough to remove grease and grime, but less strong with less potential for damage than a degreaser or other strong cleaners. I use Meguiar's All Purpose Cleaner Plus, though they no longer make it. Simple Green would be considered an APC, though one I've found to be somewhat corrosive (I'm not a Simple Green fan).
