DarkkHelmet
I posted here a while back about a problem I was having with the blower with the climate control. I took the blower out again and did some testing. I bench tested the blower and it works fine. I checked for voltage at the blower connector and it's 13.2 with the engine running and the A/C on. I connected the blower outside the housing and activated the A/C and it worked. I partially installed the blower and tested again and it worked. I fully installed the blower and it worked for a few seconds and then nothing. Manually changing the blower speed has no effect. Does that only leave the blower speed control or the climate control? Is there anything else it might be?
