jackfit
The hardest thing to face is taking my car off the road. It is winter and time to finish my restoration in preparation for this summer's great adventure trip.
My cluster was installed before the paint job and the result was a cluster full of dust on lenses.
Here some pictures of the removal of cluster.
Fist , remove driver seat for room to work, take out steering wheel and column all in one piece
Very easy, just unbolt steering buckle, clutch spring, firewall cover of column and all 4 bolts that hold column under dash. Also unplug turn signal and horn wires
Next put long bolts in dash to allow extension of cluster to remove lights and plugs , air vent lines and oil gauge
Also unscrew tachometer at distributor so cable can be extended as you pull out cluster
You can then reach up and unscrew speedo cable and tach cable from cluster , also unscrew trip cable , but leave in dash support so that you can just screw back in later.
Slide out cluster and unplug everything
I have labeled the back of my cluster so that when I am upside down, I know where all plugs and wires go
My cluster has a lot of war wounds, ( Sun speedometer put in 1972 patched up hole in back of cluster)
Speedo out first, clean lens and dial and put back in , remove small gauges , clean and put back in
To put back in , long bolts to support cluster and plug everything back in , you will notice my harness has long wires, I added 4 inches to all wires on new harness so that I would have room to move cluster in and out and be able to reach up and plug in wires
Job done
Job done
