Clutch Click/grind - replacement?
meridian6
Pennsylvania
1992 LT1 White Convertible America3
C4 1992 LT1 6-Speed manual. 60K with 20K on existing clutch. Just started grinding noise when clutch is pushed all the way to floor. If you ease off about 1/2 inch, grinding noise goes away and you hear a clicking. Ease off 3/4 inch and all noises go away. Shifts in all gears fine, no slipping or hard shifting and no noise. Just the grind/clicking noise if clutch pushed to floor (of course this happens when not extremely careful or when starting). I bypassed clutch starter power switch so I can start without pushing pedal to floor and put 3/4 inch block behind clutch pedal. Right now, just avoiding going that deep on the clutch pedal. Any Ideas? - definately no bearing shrieks.
Since I guess I will have to "GO IN":cry , I will be ordering clutch kit.
Recommendations for "everyday driver" ?? Buy GM or are Mid-America clutch kits OK??
Thanks Guys.
Throw Out bearing is Take'n a Crap!! Fun,Fun,Fun!! If I go to the Trouble to take it out a Genuine GM go's back in with a Genuine GM Slave Cylinder!!!!:upthumbs
I go along with GMJUNKIE on the parts except the Slave Cylinder for the C4 they are junk and here is the best one.
NAPA auto. PN 360017.
The master is NAPA PN 39763
