Stallion
Okay, here's the background story. In the past two days, I've noticed that it's been harder to shift. Like yesterday, for instance, it was rather "crunchy" to shift into another gear. Today, it got exponentially worse.
To the point that tonight I couldn't shift into or out of any gear. Wasn't sure what it was.
Then I noticed something. The clutch was grabbing about only 1 inch from the ground (different from the "usual" 3 - 4 inches it took to let off the clutch pedal to start grabbing a little bit). Then I realized that when the clutch was let all the way out, it was "mushy" and had no resistence for about 2 - 3, maybe 4 inches. So the range of my clutch has been minimized to just about the floor of her.
I first thought it might have been the transmission going. But then when I realized the clutch wasn't really totally disengaging I think THAT might have caused the "crunchy" shifting, and the lack of shifting later in the night. If the clutch doesn't fully disengage shifting can be lessened or halted (like I have), right?
The only other information that I have is this: I think there might have been some sort of fluid around the clutch pedal. It felt like an oil, it smelled like one. I'm GUESSING that the hydraulic booster (don't know too much about this newer '96 Corvette yet, but I'm pretty sure it's hydraulically assisted with the clutch) is shot, hence the leakage and the lack of clutch-disengagement.
What do you think? Does it sound like the hydraulics of the clutch? Is this a pretty hard problem to fix? Suggestions/advice?
Thank you.
Thank you.
