Been a while since I've been on here, but still plugging away at the Vette. Having problems now with an aftermarket clutch master and slave cylinder assembly that was put on a couple months ago. I've put only a couple hundred miles on the car, but one or both has failed again and I can't get in or out of gear. I haven't been able yet to jack the car up and see if it's just a hose, or if it's the whole assembly, but I know I'm out of fluid - even if I hadn't seen the diaphragm in the cylinder sucked all the way to the bottom, the large clouds of smoke from under the hood would have given it away.
So - anyone know of a GOOD master/slave brand, or GOOD hoses to use? My mechanic says the parts are discontinued by GM and he's forced to use cheap foreign stuff. My Vette apparently objects to that...
Thanks much
[RICHR]
Thanks much
[RICHR]
