G Winter
After many years I finally went out and purchased a corvette. I found a
1990 convettible with the 6 speed. Often but not always , usually when the
car is good and warmed up I get a clatter which seems to come from the
bellhousing area. Most of the time when I press the clutch pedal it either goes
away or decreases. I don't have to release the clutch to make the change in sound. I have no idea what kind of clutch setup these cars have. Is it a hydraulic throwout bearing ? any ideas on this noise would be apreciated .
Another little noise is a kind of groan when I first move the car. about 15 seconds after starting the car. Is this the antilock system testing ?
The engine also seems to have an uneven idle. Not always the same. Some
days very smooth other days rough almost to the point of a miss. I have replaced the plugs and plug wires and the dist. cap and rotor look good. Any
ideas on this ? thank you
