krnlpnc
In desperate need of advice on this one...
Issue: After a few high RPM shifts, the clutch pedal becomes firm and then sticks to the floor. If I slow down and pump the clutch pedal a few times, it returns to normal. The car has actually been in this condition for over a year and is absolutely fine on the street under normal driving conditions. But after 2 laps on a road track or a few drag races on the street, the pedal goes hard and then sticks until it cools down (which it does within 60 seconds).
Attempts to fix thus far: replaced clutch master cylinder and throw-out bearing. The clutch lines are heavily wrapped in thermal tape and I've tried SRF clutch fluid to avoid a boiling issue, however the problem remains easily reproducible.
Background: the car is only mildly modified and putting down about 370hp at the wheels. C5 Z06 clutch and aluminum flywheel have been installed for about 2 years. LG long tube headers. Car has 95,000 miles...she's no garage queen.
It's at the shop now and my mechanic is running out of ideas. He's next going to wrap the headers in thermal tape trying to isolate if it's a heat problem.
Anyone else run into this? Any suggestions are greatly appreciated!
