Gorgon
Seems it's almost time to get a new clutch installed but I wanted to ask some questions here before getting it changed. My clutch has recently started to "slip" but it only does it occassionally, like when first starting from a dead stop. There is a breif spot where it seems like it slips and then catches and there are no problems once I'm rolling. Does this sound like a clutch problem? I topped off the hydraulic fluid and it helped as it was low but it's starting again.
If it's clutch replacement time how much am I looking at? I understand the rear of the car needs to come out to get it replaced and I assume I'll need an alignment when it's all put back together? Recommendation on parts? C5 Z06 clutch? For the same money should I look at other clutches? I'd appreciate any input.
Leon
Leon
