Donne Trav
Is it necessary to access any coolant hoses or drain the coolant when
removing a bad or replacing a new clutch disc assembly? Ever since I got my ride back from the dealership 2 weeks ago, who did the clutch work, I've had coolant issues. I've smelled and noticed coolant in the engine bay — on passenger side just behind headlight and in the area outside and above the recovery unit after engine has had time to really heat up. I can't see where the coolant is leaking or sprouting from, but recently I saw it dripping on the ground. The area around & the front of the water pump (replaced 8 months ago) appears to be dry/normal. Thanks
