cscarlson
I have Code 10PCM PO174 HC showing up on my Corvette Computer..
Means Fuel Trim System Lean Bank 2
How do i fix it?
How do i fix it?
Where do you get Red Line Complete Fuel System Cleaner ?
I had the same code and a rubber hose comming off the pvc valve had a hole in it.REPLACED THE HOSE-no more codes!
where do you get the plastic fitting? part #
Don't have a number for you, but I'm sure the Chevy store will have exactly what you need.
The cost of the fuel pump and installed around $1500o.k.good luck with your repairs and happy holidays!
