MARCUS VETTE
Hi,
I have a little problem with my Corvette.
Fist I had EMC code 22, 33, 34 and 36. OK run, still running great
So now, I have one more code and my engine going wrong, (code 32)
When the engine is cold, I can run for around 15 minutes OK. After that, the engine can’t keep the RPM. I run at 60KM at 16 RPM and the RPM drop to 8 RMP, and make some backfire. If I put gas pedal at floor, now problem, the RPM going up. The engine runs and for some reasons the RPM drop sometime at 4 and 3 RPM, the engine can’t keep the RPM constant?:confused
I checked, vacuum line (OK)
I change my ERG valve for nothing, (the old one is good)
I check ERG Temp. switch, it look OK( I check the wire between the switch and EMC with my ohmmeter (OK)
I check the wire between the solenoid and the EMC with my ohmmeter OK
Do you some idea!
Marc
Do you some idea!
Marc
