O
omega1940
I'm at my wits end and so is my mechanic. I have a completely rebuilt 88 L-98 with 383 stroker (cam, rollers, roller assembly, four bolt main, etc. etc._), and enormous power/torque.
About 2 months ago, I started "throwing" a code 33. I would get a slight "stutter" in the throttle, then the code would show up and the car ran like it had 2 plug wires pulled. I could turn if off for a couple of minutes, fire it up and drive for a couple of days with no problem. It has continued to this day, when it did it 3 times just today. I replaced the MAF with an adjustable high flow MAF, and it would work for 2 days then it would set-off again. My mechanic suggested I reinstall my OEM PROM chip and I did that. Still did it. I have a 52 MM Throttle Body that is about 2 years old and have no reason to suspect anything there. I replaced the burn-off and power relays Tuesday night (for the second time) and it ran all day yesterday without a problem. I thought I had found the problem. Then today it happened 3 times. When my mechanic plugged his digital reader into the plug-in under the driver's side dash (can't think of what they call it) he said it appeared that the MAF was showing the right amount of air density, then suddenly it would go up very fast and set off the code 33. As I said I replaced the MAF. I even went back to the OEM MAF I had (actually it was slightly modified, but wasn't adjustable) the code 33 problem still occured. We have checked the wiring to see if there is any problem and there is none, including the connector to the MAF. Timing is perfect. I just can't believe that with a pretty straightforward system like the MAF, relays, etc. that we can't find out what's going on. When it dumps the 33 it runs so bad I have to keep revving the engine until I can pull over and turn it off or it dies on me. PLEASE, PLEASE PLEASE HELP!
Anyone reading this from the Phoenix area I would like to get a referral on a Vette mechanic. Mine is great for the regular stuff, but not like this problem.
Mike
PS: Jeff DeBur is reprogramming my PROM for the stroker right now. I'm holding out hope that this could solf the problem, but I'm pretty pessimistic right now.
Mike
