Mad-Mic
Gone but not forgotten
ok i finally got the car scanned as my friend finally had time to stop over with his scanner. after changing the O2 sensor the car felt like it was fixed and was pulling hard down low and spinning 275/40/17" BFG DR's over at will thru 2nd gear. (Ask Rich R about the ride i took him in
) well the car eventually went back to it's sluggish self on the low end again.
Code 36 came up which is the MAF and or Relays. it's dark out now and i haven't checked the MAF wire yet but will tomorrow when i find some time. my question is if it's the relays where are they located at and where can i buy them at? if it's the MAF itself i'll see if Rich will let me borrow his old one for a few weeks until i get some extra fundage in the pockets and will spring for a new aftermarket one that is ported. which MAF do i go with?
at idle upon startup the car is pulling over 10 grams per second past the MAF itself. stock setting range is 4-8 grams per second. is there anyway to check the relays? if so how and where are they located?
thanks for the help!
Mic
Mic
