Vetteophile
- Joined
- Aug 23, 2010
- Messages
- 18
- Location
- Toledo, OH
- Corvette
- 63 Coupe, 77 Coupe, 86 Coupe, 94, Coupe
Can anyone here set me straight on 327 340hp heavy cam engine on the following?
Coil - I read that coil should be 1.7 ohms resistance on Primary.. and not less than 11 on Secondary. All aftermarkets seem to be around 9 on Secondary. This a big deal?? or should I just get a stock coil and not worry about these numbers?
Vacumn Advance - lots of good articles on this forum about base....centrifugal...and vacumn advance. Since my vac at idle is low at about 7 (idling at 500), they indicate I should get a control unit that starts about 5" Hg, and is all in at 7. Problem is... where do I find a vac like that? Apparently Echlin used to offer one called a VC1810, but its discontinued. Any ideas on an alternate?
