Peer81
From the beginning my carb has this thing, after rebuilding everything I thought I would find what was the problem but no the fenomenon is still there.
What is the "problem"?
When I start the engine the choke is on the second step (why not the highest step?). But no problem there, idling a little ruff but no big problem. After 2 to 5 minutes the rpm goes up from 300 to 400 rpm! Idling nicer without any problem. I was working on the carb today to get the choke rpm up so I could see everything when this happend.
The carb didn't change anything, I always thought the choke would go to the highest step but that is not true. The choke itself didn't open or close more then before or after.
As the coolant temp is about 100F by then I would think that is still to cold for the ECM to kick in but as I have a heated O2 sensor, the o2 sensor would be operating by then.
So who also has this fenomenon? And has it something to do with the ECM?
Greetings Peter
Greetings Peter
