S
sscam69
Well a few notes for you guys out there who want to run this setup.
One its the first time I see the temp drop at idle and the first time I see the car run close to 200 (before was 220) and hold.This was done at night, approx 80 deg outside. We are reaching over 100 deg on a daily basis.
That says that its displacing a lot of heat.
BBBUUUTTT......
Its suppose to be able to cool 600c.i. and up to 1000hp. Techinically this setup should be OVERKILL BIG TIME but something is not right with my engine, I think.
I just got it rebuild and haven't changed the oil and have put 1000mi on it. Its time to change the oil, I hope this helps. Going synthetic.
The oil pressure is reading 40psi at 2500 rpm but is suppose to be a high volume oil pump. My dads van runs at 40psi at idle and 60 at cruising speed (70mph). Whats it suppose to be? I am thinking the its hot cause of the oil is not providing enough lubrication.
There is a gap in the spal fans between the radiator and the shroud at the top and bottom of the fan shroud. I put weather stripping to seal up the fans agains the radiator so that the air would get sucked through the radiator not around.
Another thing, I think the electric fans are killing my alternator. The headlights look dimmer as well as the interior lights and the car was harder to start after I ran it. I had the fans hooked up to the battery as per the wiring diagram of the relay but only got 10.7 volts across the fans. They need 12V. So I hooked it up directly to the positive of the alternator and I am getting 12.3 V across the fans now and what a difference in the pulling of the fans!
I am thinking I need a better alternator! 140 Amp. Its an investment since I will be using more electronics in the future.
Any comments, concerns, questions?
Frank
BBBUUUTTT......
Frank
