RPM's96
I am looking to spend about 5K+- on a complete rebuild on my 96 LT4. My mechanic and engine tech will be collaborating on this, I am not a motor builder by any means and this will be the first time I have spent this kind on money on a build. I am counting on them to find balanced parts for a motor that will be a significant improvement over stock for use as a frequent durable driver, not raced, but spirited driving form time to time. The whole rotating assembly will be new, valve train, .060 over, hot cam, possibly some head work and MSD Ignition.
I am in CA so it needs to pass smog here :ugh. I am thinking I cannot get the most out of the motor without a tune. Will this be a problem as far as smog goes? Any way around it? Any good tuners in the central CA area?
Also (separate budget) will have a (Center Force probably) clutch installed.
I have seen varying opinions on MSD ignition vs stock opti.
Parts recommendations/combinations including clutch. I had thought of going steel flywheel instead of the stock cast, but was advised not to cuz it is a minor improvement. Don't want aluminium.
Also I am wondering if there is anyone in the area that can work on the ZF6. My mechanic says he has only heard horror stories about those that have tried. I know about the ZF Doc. Just wanted it freshened up. It is shifting ok, but has 70,000+ miles on it (like the car) and as long as everything is apart...
I hope to tap the deep well of knowledge here and would love to hear from those of you that have been down this road, and may have information about what has worked for you, or not, and why.
Thank you
Thank you
