- Thread starter
- #21
skitch
I'm planning on doing all the labor myself. I have a shop and plenty of tools. I'm more of an old school guy, but if I take it apart, I can put it back together. After all, if I can build and rear end for a top fuel dragster, how hard can it be?I put in the 24 lb. Accel injectors and now she runs like she just left Bowling Green! The actual spec is something like 23.92 lbs. If you want even higher performance, there is a company called RC Engineering that makes injectors, but they run $80-100 a piece, which is still half the price of AC Delco!
Be careful when you look because some web sites will say that 30 lb. injectors will work on this car! I have never done this, but I understand it takes some reprogramming. Also, do not get remanufactured or refurbished injectors. Brand new ones don't cost that much more.
As far as the leak at the intake manifold... well... this is pretty expensive repair... like 4-figures expensive, most of it being labor.
But still... it is all worth it, IMHO. But then again, I am biased!
The only thing I need to sort out is who to buy injectors from. I've heard FIC a couple times so I will look into that.
Mofo is dope!
