Where oh where does my little ground go.
On my 72, under the shifter plate (auto) there are 2 black wires that go into a common clip. I suspect that they should go to the bolted on tang that is on the side of the heater control, however, there is already a single black sire on that tang. it goes into the harness and up towards the speedo and tach. I've seen other GM's where there was a tang on the cig-lighter for a separate ground but this one has only the center hot tang.
Anyone with a better wiring diagram?
Mooser
Mooser
