Okay, swapped the computer this morning and a couple of things happened...
1. Blinking check engine light is now just a solid check engine light!
2. The constant "clicking" I hear from the carb just before starting (normal) I think its the MC solenoid...now no clicking, but it still starts.
3. Tried to pull codes by jumping the last two terminals on the right side of the connector under the ashtray. No codes, light just stays on solid...I do hear a single "click" from something out in the engine area, but it just happens when I make initial contact with the paper clip.
4. I drove it, and it seems to run slightly better, but I still have some hesitation when I give it the gas, and it just doesn't seem to be running smooth.
A couple more things...I set base timing and changed the O2 sensor (with the correct two wire sensor) thanks. When I checked the timing after the shop set it, the timing line was way above the scale, maybe 16 or 18? As I rotated the distributor it brought the line down into the scale, but it seemed like the engine idle was slowing way down (almost to a stall), finally just settled on about 12.
So that's it for now, I'm not sure how to get the codes if the light won't blink and get the MC solenoid clicking again. Any ideas?
Thanks for all you help.
