Kid_Again
- Joined
- Jul 6, 2004
- Messages
- 1,171
- Location
- NJ - Which exit you from?
- Corvette
- 65 SB Roadster, 66 BB Coupe
...the coolant leak is fumunda my new electric water pump :gap
..OK, I reinstalled the controller for my Spal fan and I also installed the Moroso water pump and that's where I need your advice..
I fired it up after all the fixes/re-fixes and the most important part to cover first is coolant leaks from both the lower radiator hose connector and the upper heater hose connector....the upper hose connector shouldn't be a problem but the lower fitting will be tough to tighten (it is completely round adapter that goes from 1.25" OD down to 3/4" NPT (I believe))..anyway, it's a reducer to take the hose to the pump......the major problem is the threads in the pump housing are really rough and i want to use a very thick sealant on those threads for both fittings to make the best seal possible -> what would you recommend?
...now, all responses to this next question are welcome but i tend to rely on my wiring guy, VNV......I want to vary the speed of the electric water pump and be able to switch it on and off....i want to switch it off because there's no need to draw extra power when i crank it up....i would then like to vary the speed, even if all i have is the ability to go "off-half speed-full speed" and I assume that i would also run the water pump through a solenoid - not sure - but i also don't want the cockpit to look like they had a sale on bling at radio shack...any ideas?
....BTW, the electric pump, running at constant speed, does a hell of a job keeping the sb cool...it simply would not heat up beyond the tstat setting, the fan did not kick in......I figure that i can get at least as far as VNV's driveway with the setup that i have now
..then, finally, my battery died on the sb...the "amp" gauge didn't look all that bad when i drove the car but when I load tested the battery :eek ...i tried charging the battery out of the car on the big charger and it would not take less than a 20 amp charge..OK, new battery after 5 years....BUT what i did notice was corrosion on the battery cutoff terminals and i suppose I learned another good lesson about battery maintenance:eyerole
