VIN_#_00521__Z-51_C4
- Joined
- Mar 5, 2007
- Messages
- 157
- Location
- omaha....It's spring time and
- Corvette
- 1984 C4 DOB 01/13/1983
Need help with this......................
My '84 ( when i bought it, Never had a properlly functioning fan switch.... I knew it had the problem, and added a switch to turn it on at a certain temp, I have replaced it and it still will not turn on at temp ( What is the turn-on temp for theses vettes, i heard 240 and it definately did not turn on at 240 even 260 when the coolant was starting to Boil over in the bottle.........Heres another thing the wierd behavior i have noticed with the fan switch.........i was driving home and did not turn on the switch as i was on the Highway Did not notice a change in temp it hovered @ 207 all the way
I pull in to the Oreillys to buy fuses and when i shut the car off..... The fan is running on its own( it switched on while driving ) Heres the Kicker! I never turned on the switch( that will turn it on manually ) it was running but at a slower speed, I flipped the switch and it picked up speed, turned the switch off and it was still running after a while it shut down on its own................I did put in a new battery recently and had the cables unhooked for awhile while i installed the battery is it the fan itself or maybe a Relay to the fan because i just changed it Does that relay help it turn on at the right temp or allow it to function period
Any suggestions i need them fast
What would make it kick on and stay running then shut off long after the car was shut off now I have a new fan switch in and it will not switch on by itself is the Temp switch bad, should i change out the stat
Any Help with this would be appreciated
