cooling fan
  • Thread starter Thread starter LOUVETTE
L
LOUVETTE
i hear a lot hear about cooling fans............i only see one on mine ... right where they all are on all cars
If optioned so....your C4 should have a small booster fan on the front side of the radiator.
reply
does it kick on the same time as the other fan
Primary should come on around 220 Secondary around 230
The primary should come on also when A/C headpressure is up - which is just about any time the A/C is on.
The fan out front will come on at 228F.
Or not at all...
Not sure about this, but I think the aux/fan is RPO BP4.:D
fan
thanks for the response.....i dont have code bp4 and i dont see a aux fan ...just the one under the hood where a fan will normally be......it comes on at 229 ideling or when i turn the air on.....cools it down to about 218 before shutting off...........
There's a fellow in the Atlanta area selling the aux fan on E-Bay, brand new, for a really good price, "Buy it now" for $45.
I got one from him two months ago, it was exactly as represented, a new in the box GM part for the C4 Corvette.
Installation might take you an hour if you're working carefully and meticulously.
Wiring is a separate issue. I recommend getting a solenoid and controlling it through a switch under the dash.
Regards,
R
Your 84 probably only has one fan. Ours did. We ended up mounting a second one where the normal auxillary went and wired it to the primary so they both run at the same time. made a big difference on how cool it ran. We also by-passed the switch and grounded the wire so it runs all the time. We are in sunny Tucson, AZ so it is warm year 'round here. :cool
