90steelbluevette
I seem to be having a problem with my cooling fan. I just replaced the thermostat and now if you sit in traffic, the fans will not kick on. I am trying to figure out if it would be because I bypassed the Heater Core (it is clogged). When I turn on my AC the main fan will come on, but not the secondary. Otherwise no fans will come on.
Trying to figure out if there is a temp switch on the heater core or something. I am going to replace the relay's and the Fan temp switch and see what happens. Also, is it typical of these cars to "when sitting" to heat up until the fan temp switch tells the fans to come on?
