cooling fans
muddywaters
wilkes-barre,pa.usa
1988 white 4+3 coupe 99 Torch Red 6spd. coupe
hi, i have a 88 vette w/optional oil cooler w aux. fan. at what temp. should these fans come on thanks
Stock, the fans will come on when the coolant temperature reaches 230 or so.
The pusher fans come on at something in the 225&#176 range, with the main fan coming into play at around 235&#176. The temperature at which the fans turn on is 226&#176-235&#176 from the factory because of emissions requirements. Most cars will operate at 190&#176-210&#176 on the highway and will go upwards to 240&#176 in the city.
I hope it helps you.
_ken :w
If you want them to come on sooner, talk to Jeff, one of the Moderators. He helped me out!
