Correct Intake Manifold Gaskets for L98?
jgmotto
Georgia
Does anyone out there know the correct part number for an intake manifold gasket for an 89 L98 with stock aluminum heads? The parts store listings show a lot of different ones. Some have the rear port blocked off. Some have the center port baffled with metal. All different port sizes. I have a set of 1256 Fel-Pro and a set of 90314 Fel-Pro. Are either one correct?
Correct gasket has a metal plate with a small (1/16"?) hole on rear coolant port.
Center (EGR ) port style is irrelevant as alum L98 has no EGR passage there in either head or intake
