- Joined
- Oct 7, 2007
- Messages
- 720
- Location
- Amherst, NY
- Corvette
- 1996 Torch Red Coupe (Prior 1988 and 1989)
I'm trying to resolve a delayed or extended start condition on my 1989 L98 (all stock) with 56K. It does this under all conditions; cold, cold restart, hot, hot restart, and hot soak. No fault codes. It always cranks, so I don't think this at all related to VATS. Here is what I've checked out so far. TPS showing .54V at idle and 4.6V at WOT with smooth voltage change between idle/wot/idle using either analog or digital meter. Coolant sensor is showing correct resistance of 7.26K at 41 degrees F. Fuel pressure holds steady at 40.5 PSI during on and start with vacuum line attached. Pressure remains high after shutoff. All 8 multec injectors were replace by the prior owner at a Chevy dealership in 2003 with new multec injectors. All eight injectors measure between 15.8 and 16.2 ohms. The 1989 L98 has no cold start injector. Once started, runs great at all RPMs. Just replaced the cap, rotor, plugs and wires. with AC parts. Old plugs were worn but all showed proper color. I find the best way to start the engine is to crank twice vs. one longer crank. Looking for suggestions on what to check out next. Ignition module? If the EGR was stuck open, shouldn't I see idle issues? One other item that may not be related. If I start the car cold and let it warm up in park, it may stall out (say 1 out of 5 times) when the dash temp reaches the 100-125 degree range. I have not cleaned the IAC.
