RoadReady
Help! My '96 LT1 seems to have sprung a leak around the Crankshaft Position Sensor. The manual simply says to lift the car, loosen the bolt and remove the sensor. Yeah, right, I can barely see the thing much less touch it! There are two braces bolted to the crossmember and the side rails. Is is safe to remove one of these braces with the car on jackstands and, most important, will it give me access to the sensor?
Thanks for any help
Thanks for any help
