I'm planning on dropping the motor into my 69 on monday. This is the first time doing this for me. Any advice or guidance I can get would be great. I'm not sure if I will be able to fit the motor and transmission in together. Also how does the clutch and flywheel attach, and what is the significance of the motor mounts and what should I use? Just a GM motor mount? Right now the shifter is off, but the linkages are attached to the 4 spd. will I have to attach the shifter? I know this is probably a lot to explain but any help would be appreciated. Thanks
