Koop
- Joined
- Mar 16, 2005
- Messages
- 545
- Location
- Kalifornia
- Corvette
- YELLOW 69 modified GM Crate ZZ383, LS2 TBSS
76 Sting said:What carb setup do you have, as this is the last piece that I am trying to decide on.
I have the stock Quadrajet but it has been rejetted it works fine. I've been told a bigger carb won't help since the Quadrajet can move more fuel through it than the 383 can use (the jury is out on that, a bigger carb could be in my future, I'm thinking about cutting a tuner loose on the car). I did have to upgrade to a high flow fuel pump and you're gonna need deep groove pullys. You will probably lose 15 or so HP and a little TQ if you run a dual plane manifold, it seems the dyno guys like to use a single plane when they search for the highest numbers to advertise.
