L
lonestarvette79
I have acquired what I believe is a GM crate engine but I have no information to ID it. It is has late model chrome center bolt valve covers, angle plug alum. heads and was probably purchased as a long block.
The only numbers accessable are the block casting: 16006036 with the words "Hecho en Mexico" (Made in Mexico) and, 2M0322 on the number pad. The casting number continues to show up as a 94 model 350 engine made in Mexico.
The engine has enough cam to have a slight lope and is currently hauling around a 4000 lb '77 Monte Carlo like a bat out of Hell!! I am wanting specs if I can find them because it is going into my 79 Vette after I add a tune port setup to it.
The guy that I bought it from could only say that it was a 350 with alum. heads and had 300hp.
Possible ZZ3???? All internet searching has led me nowhere. Any help would be greatfully accepted.
