ironmoo
My '82 has the bone stock setup. The intake manifold leaks (or hairline crack) on the driver front side as a very small amount of radiator fluid is pooling in one of the depressed areas below where the front bolt is attached.
I bought a 2nd and 3rd crossfire setup off Ebay I wish to rebuild and learn from.
Here is the situation...
I teach college-level Physics, have rebuilt small block engines & build home computers as hobbies…
However I've had this car since 1986 and viewed the Cross-Fire system as something of a mystery and have not been sure what does what and how it does it.
Like what is duel plumping? MAP sensor, voltage checking throttle position voltage off idle, etc etc... lol
More importantly how to tune it myself/maintain and address issues like the current "check engine" light. While it may be a vacuum leak, I did replace both O2 sensor and EGR value, but the light still remains lit.
Reading through the posts have been helpful however it seems the running theme is, while finicky, proper tuning can bring great results from the Crossfire engine.
I do wish to learn to do that tuning!
If someone can provided a source online or simple diagram.../or explanation what all the sensors names are and do in the engine process, that would be of great help get my arms mentally around this engine!
One thought is to buy ALL the sensors/wiring etc and start fresh...The car was paid long ago so cost for parts to diagnose, and to travel a learning curve to master it, is well worth it.
Many thanks in advance!
-Moo
-Moo
