V
		vmrod
I want to get my cruise control functioning again on my 1977 vette. (It never worked when I bought it.) I know that I have to attach 2 cable to it (speedo from xmssion and speedo to gauge). This I can figure out for myself.
I need to know, what vacuum lines go where? I assume that a vacuum supply is needed. (Does it come from the manifold, the vacuum resovoir or carbeurator vacuum, or does it matter?) Where does the vacuum supply plug into the transducer?
I suppose a vacuum output connects to the vacuum canister that operates the little chain which in turns pulls on the throttle linkage. Where does it connect on the transducer?
Finally, I assume that the transducer must get a signal from the cruise control 'setpoint' button on the steering column. Is this signal a vacuum signal, or is it an electrical signal? (where on the transducer does it plug into?) I suppose if it utilizes an electrical signal, then a power feed must be run to the transducer as well. (If so, where does it connect to?)
A simple diagram would help. My car is not really original, so I do not need exact procedures. (example...plug blue hose into this...) Instead a general 'howto' would be beneficial. (example...vacuum reservoir plugs into transducer top hole...etc.)
-Vic
-Vic
