R
RocketC4
ok well my cruise will not work not a thing no indication light nothing. I have no experiance with this system so I don't know where to start. somebody help.
It could be a vacuum leak. Check the vacuum hoses at the cruise module.checked the fuses there good what else should i check
There is a check valve under the passenger side fuel rail cover, check it and make sure that it is not cracked. It's only a $5 dollar part. Search this forum for "cruise control check valve" and you will find the part number to ask for in another post.It could be a vacuum leak. Check the vacuum hoses at the cruise module.
