fine69
- Joined
- Dec 12, 2004
- Messages
- 975
- Location
- Maryland / D.C.
- Corvette
- '69 Convertible Vette; '72 Z28 Camaro Rally Sport
CS1062R Sealed Power Performance Cam - Specs for Springs and Pushrods?
Hello All,
Thanks to JohnZ, Jack, and JHL I decided to use the Sealed Power Performance Cam (CS1062R). I was able to order this cam from Racer's Outlet in Indianola, IA. Their phone # is 515-961-6109, if anyone is interested.
Do you think the Performer RPM springs will be okay with this cam?
Here are the specs for the springs:
EDL-5767 Edelbrock Sure Seat Valve Springs
Outside Diameter of Outer Spring (in): 1.460 in.
Coil Bind Height (in): 1.130 in.
Inside Diameter of Outer Spring (in): 1.060 in.
Inside Diameter of Inner Spring (in): 1.060 in.
.... and here are the specs for the cam:
Int. Duration @ .050": 220
Exh. Duration @ .050": 231
Int. Lift: 468
Exh. Lift: 480
Lobe Separation: 110
Also, I previously used +.100 pushrods, would this size be okay?
Sorry for all the questions, I want to be sure I do it right this time around.
Thanks,
Ralph
Hello All,
Int. Lift: 468
Exh. Lift: 480
Thanks,
Ralph
