F
flynbyu82
Ok, I'm still having cut-off problems with my 82. I've recently replaced air filters, valve gaskets, suspension, u joints, and a new radiator. It was cutting off awhile ago, but then I made sure the expansion tank for the radiator was full and it stopped that. Now, I had the radiator replaced because it rusted through and was leaking.
When I start the car, it sounds like an exhaust leak with a tapping noise. It stops, but then when I'm cruising and step on the gas, you can hear it start tapping again.
I havn't been driving it too much, and I don't know if I'm just retarded, or something weird happened while it was at the shop, but it's only getting roughly 6mpg, and it should be getting around triple that.
I've put techron and gas treatment in the tank, and it's still acting up. I don't know if all these things are working toward each other, but the main thing is, it's cutting off. When I'm stopped at a light, not every light, but randomly willl drop from around 800rpms to around 400, and then cut off. It usually starts right back up, but I've gotten to the point of sitting on the gas alittle in neutral at lights to keep the idle up. It's been to the shop several times, and everything that ages with the car has been replaced, but it's still cutting off.
ANY suggestions I will be grateful for, I just can't figure it out, and with school starting soon, I will be driving it a lot more, and I really don't want to get stuck in traffic because my car shuts off, or get tboned pulling out infront of someone.
In advance, I appreciate any help.
Shane
**And here's another thing I forgot to add in the post, if I put the car into park when the RPMs start to drop, it will jump back up to ~ 700 rpms, and sustain that longer than if it was in drive. I'm just throwing more information out there.
** My engine light also just came on, checked it, and it's flashing 13s, can anyone help me on that?
Shane
