vms4evr
Hey folks,
This has been discussed from time to time and I thought I'd post what I have done incase someone is interested.
I'm running the SLP Cold Air setup (used to be called Triple Threat). It's basically 3 tubes that have a K&N cone filter on each tube. Those mesh into a big tube that connects to the factory tube going to the TB.
I'll post 3 additional pics that each show what it looks like from inside the engine with the filter removed, under the car, and with the filter in place.
After I cut the hole I covered it with an eves vent that you can find at any local hardware store. I use a small peice of door molding rubbber between the vent and the shroud to act as a gasket to make a better seal. Cost me less than $5. It's metal and has a built-in screen so bugs and such can't get in there. I can also easily add a piece of AC filter material in it if I want to tone down the dust and pollen mess in spring time.
Now some folks got really concerned about water ingestion. So I didn't post this earlier until I got many months and miles on the car to verify it wouldn't fry the engine. This car is a daily driver and has been out on the road in heavy rain numerous times and I have had no problems. In fact the area that gets all the water is on the sides because of the pop-up headlamps and the openeing below them. The area around the air filters has never been wet.
First pic is everything assembled.
Graham
Graham
