cyclic vibration
frltsta11
plant city
97 coupe
I have a 97 coupe that has a vibration starting at 55mph. I replaced the tires and the vibration is still there. The tires have been balanced and the car aligned. What can be other problems that could cause this type of vibration?
Hi there,
Does the vibration happen when you are accelerating, or coasting to a stop?????
Do you have to be on the brakes or off????
Does it make a difference what gear you are in??????
Please let us know, and we can proceed.
YoursinCorvette, c4c5:hb
the vibration doesn't start till i hit 55mph. This during acceleration.It smooths out a little at about 70mph. I have an automatic.
HI there,
If you put the car in neutral, at the speed indicated, is the vibration still there????
Is the vibration there in 3 as well as 4, at the speed indicated???
c4c5:hb
