Cylinder heads
  • Thread starter Thread starter Racerseks
R
Racerseks
I have the opportunity to get a great deal on some alluminum performance cylinder heads. Any comments on what I should consider? I plan to keep the car relatively stock.....just a little fine-tuning (ignition, exhaust, etc.) Thanks!
What's a great deal, and what heads exactly are you talking about?
A cam and some intake work would be nice for some additional power :w
As a caution from someone who's just been there, some "deals" on heads may not be so good. If you can, test-fit a gasket to all the ports and make sure everything lines up right and there are no gaps. For one reason or another (I've been given several), there are a number of heads out there with intake ports that are farther out from the valley than they should be, and this causes MAJOR vacuum leaks.
[RICHR]
