Okay, I need to figure out what I'm going to do with my cylinder heads. What I do know is that my car won't see any of the track and it won't see any racing. It'll just be a driver.
That being so, I don't know if I want to spend $1200 on a set of heads. I don't need bigger valves and I'm not going to do a radical cam. I may even stick with the stock cam if there isn't anything wrong with it but I'll get a little more lift with 1.6 roller rockers.
I've got some new injectors on the way from Five O. and I want to redo the heads as well.
I read an article on porting your own heads. It didn't look that difficult but I don't know if that's something I'm ready to undertake at this point.
Another thing I'd like to do is port match the intake manifold with the heads. Then I'll port the plenum and get some large tube runners.
What I want is a street machine, not something to run the 1/4 mile with.
Any suggestions?
What I'm thinking right now is to rebuild the heads to stock specs. I would like everything in there fresh so there won't be any problems. I see that Scoggins Dickey sells cylinder head kits for about $120 each head.
Any suggestions?
