Dash help
bell
C. Florida
95 ZR-1 Blk/Blk
My 90 has no daytime dash lites and my DIC buttons do not respond when pushed.
Any thoughts or advice??
You might get better results if you reposted this to the ZR-1 Forum. Us plain ole C4 types might be reluctant to jump in. Although your dash may be the same as any other '90. If so, I'll take a shot and ask for more info:
1. Do you see any difference whether your headlight switch is on or off ?
2. Do you have a small window at the upper left of the dash, near the headlight switch? If so that is the daylite sensor. Try shining a bright light into it for 15-20 seconds or so (with the headlights ON). Does that make any difference?
3. Do any lights on the panel work (Radio, A/C, Turn Signal Indicators. High Beam indicator, fuel gauge, Babe Alert, etc.)?
4. Do any other interior lights work (Courtesy, Console, etc.)?
HTH
