dash lights
baas85
ostrander
1985 coupe
I just noticed that my dash lights are only bright for about 2 seconds, just as I turn the key past ignition. Then they got to a very dim mode. Every once in awhile they will work fine. Any ideas, I guess there is a grounding problem, that if I clean the ground on the instrument panel this might be my fix. I also have a continuous solid left turn signal indication when I turn the lights on. I have a 1985, that I have not owned for very long.
thanks;help
