D
drq1980
The left dash blinker works, but the right dash blinker does not. Its very annoying when I forget it is on and drive 20 minutes signalling a right hand turn. All the lights work except the one bulb for right dash blinker.
Question is how hard is it to replace the bulb? I assume the Speedo/Tach bezel is removed. The housing is unscrewed but then what? Is this a major job or is the bulb fairly easy to locate and install? Anyone with some prior experiance would be appreciated.
"#34 on the endless list of tiny repairs..."
"if my corvette was ever 100% I would wrap it in cotton and never drive it"
....And I hear you about the endless list....Mine is like a fine lady...HIGH MAINTENANCE, but fun to play with
ad.....A changed light bulb turned into a dropped steering wheel and a cluster removal with the quickness....Oh well, live and learn and share so someone else doesn't make that mistake.
