Use a Buck knife! Naw, just kidding! (That was an answer I got from a suspected car thief in the "interview room, once.)
To get into the locked vehicle when you have a dead battery~
1. Utilize your key hidden in your FOB to unlock the trunk lid. (Keylock is just above the license plate.)
2. Pull the cable release to the driver's door. (Should be on the left side wall.) There's also a fuel door release too.
3. Once the door is open, just pull the hood release down by your left foot well.
Now, if you've locked your FOB in the car and you can't get your other FOB, here's what you do~
Call AAA and have them send a towtruck. They can open your door with a "special tool" (no, it's not a slimjim.)
They will inflate an air bladder between the roofline and the passenger window about 3/8ths inch. They can then slide a looped cable to the mechanical lever on the floor. Pull it up and you're in!
Hope it's ok what I just typed...
