B
bigwingnut
1985 4+3 with no mods:
Driving down the interstate, on cruise at 75 mph, 200 miles into a 500 mile trip. Cruise trips off, car falls on it's nose. Coasting to the side of the road. Gas pedal has no effect, but idles at 1400 rpm. Temps, volts, pressures normal. Suspect throttle position sensor.
1400rpm in 4th overdrive is 51mph, so I got off to a parking area. Shut off the engine, jump the connector for the codes, and it says Code 12, 22, 33. Parked under a street light, but it's shining in the wrong place. Try to start the car to move it so I can see the throttle position sensor and vacuum line to MAP sensor...it cranks perfectly, shows no codes and I finished the trip with no problems. Any of the Techies out there got any ideas what the problem is??? The last Vette I had was a 65, and I understood it...but the new "electronical" ones have me bum-fuzzled! Thanks!!
